bathroom sink repair
Old 06-16-03, 11:59 PM
cthack27
Please provide any info and tips on faucet and drain replacement.
Thanls
Old 06-17-03, 05:52 AM
Mike Swearingen's Avatar
Cool
Heer is a tutorial from Lowe's, and you can do a Search above on the subject for many, many tips and how-to-do-it. If after viewing all of this info you still need help...just come back on this same thread and ask.
http://www.lowes.com/lkn?action=howT...placesink.html
Good Luck!
Mike
Old 06-17-03, 07:59 AM
cthack27
I still ned help
leaking trap house is 30 or so years old. Do you know the likely size and material of drain pipes from the wall for sinks in the lav or at least how to measure it? Inside di or out?
Thanks for your help
Old 06-18-03, 07:38 PM
Jimsch
The house being older, if the pipe coming out of the wall is metal it's most likely 1 1/4" galvanized as compared to the commonly used 1 1/2 PVC. Measure the inside diameter. Take the old one with you.
HTML code is On
