Gas Water Heater
Old 06-19-03, 06:12 AM
ProtectorLD
Question Gas Water Heater
I bought a house a few months ago. It has a gas water heater. The thing makes a lot of noise when I use the water. Sometimes I think it is go to bust out of the wall. It is in the kitchen. I have read a little about them, but there is never a mention about noise. Is this normal?
Old 06-19-03, 10:56 AM
Mike Swearingen's Avatar
Cool
Usually such noise in a water heater is caused by sediment buildup in the bottom of the tank.
Attach a water hose to the drain spigot at the bottom of the heater and flush the tank until the water hose runs clear.
Good Luck!
Mike
Old 06-21-03, 05:23 AM
ProtectorLD
I will agive that a try today. Thank you.
Old 06-23-03, 11:48 AM
Wick
I am not an expert or anything, but I just had a similar
problem. The heater would make alot of noise when
the water was first run for about 10 seconds. I tried
flushing the tank, still made the noises. Turns out it needed
an expansion tank. A single older lady lived there before
us. Either she ignored the problem, or never used enough
hot water for the gas to run for long periods of time.
HTML code is On
