Removing Tub
New Member
Removing Tub
I'm renovating a bathroom. But, I need to do it in stages. Should I remove ALL the sheetrock in order to install the new tub, which is the width of the room, or can I do the sheetrock before? I'm not asking about the wall area that surrounds the tub.
thanks,
Mel
thanks,
Mel
you need the sheetrock removed so you can put the new tub in. The apron on the tub needs to pass inside the stud wall as you are dropping it in place.then when the tub is level it will fit inside the opening.
