water heater
Old 06-24-03, 02:48 AM
Jazztwinkle123
Angry water heater
can i have some advice on how to replace a heating element in a water tank
Old 06-24-03, 04:21 AM
Mike Swearingen's Avatar
Cool
You can do a Search above for information on changing an electric water heater element, but:
A. Turn OFF the water heater breaker at the panel (should be a 30 amp double-pole breaker). Test the thermostat wires with a voltage meter before touching any wires (for safety).
B. Turn OFF the cold water supply to the water heater.
C. Attach a water hose to the drain spigot at the bottom of the heater.
D. Open the drain spigot and the highest and farthest hot water tap and the T&P valve on the heater for air to drain the tank.
E. Remove and replace the element(s) with the exact same size and kind. I always replace both elements, if I have to replace one, but that's up to you. Usually the bottom element will go first, as it does most of the heating.
F. Close the drain spigot and T&P valve and refill the tank and hot water lines until you have a steady stream of water coming out of that highest and farthest tap.
Do NOT turn on the power until you are positive that all air is out of the heater tank, or you could fry an element.
Good Luck!
Mike
HTML code is On
