deep well
Old 06-24-03, 05:20 PM
LDC
deep well
Hi, I have a deep well that i just pulled the old drop pipe up from. The well is 250ft deep, the water is 117ft down. The old drop pipe was 168ft down. The well pipe is 2" dia. Any ideas on what type of pump i could use? My usage will be watering the garden and some fruit trees. Thanks. Larry
Old 06-25-03, 01:41 AM
Mike Swearingen's Avatar
Cool
Please see www.peekspump.com and www.jessstryker.com for excellent tutorials on wells and pumps.
Good Luck!
Old 06-25-03, 06:53 AM
P
deep well
Larry,
You said the well pipe was 2". Is this the well casing you're talking about that's 2"?
If so, you're going to have to use a deep well jet pump and a 2" packer assembly.
You could probably expect about 3-5 gpm using a 1 hp deep well jet pump at that depth to water.
Ron Peeks
www.peekspump.com
Old 06-25-03, 02:21 PM
LDC
deep well
Yes, it is a 2" well casing. Could a guy use plastic pipe with that set up or should i use metal? Thanks Larry
Old 06-25-03, 07:55 PM
P
deep well
Larry,
There's no reason that I can think of that you can't use plastic pipe. You should consider black poly pipe. A 2" packer assembly has rubber seals on it that seal against the side of the well casing. Might be a little tough installing it, but should work ok.
Ron
www.peekspump.com
HTML code is On
