Shower "arm" with ball
Old 07-01-03, 04:04 PM
MommaFrench
Angry Shower "arm" with ball
Ok, I'm putting in new shower heads in our bathroom and just found out that the shower arms have balls at the end of them. Do I need to take them off, or do I have to replace the whole arm? And if I do need to just take off the ball... any suggestions? We tried vice-grips to no avail. How hard is it to replace the whole arm? We can't see the threads at the other end. I'm scared to screw up our showers.
Old 07-01-03, 11:08 PM
Mike Swearingen's Avatar
Cool
Replace the ball-end shower arms (you can't remove the ball) with shower arms with male threads on both ends.
Both types just screw into a mounted fitting in the wall with the showerhead on the other end.
You can use a pipe wrench or channel-locks to unscrew the old ones counter-clockwise, since it doesn't matter if you mar them. Use a handle of the channel-locks in the new showerhead end to tighten them into the female threaded wall fitting.
Wrap 2-3 flat wraps of teflon tape clockwise only as the threaded end faces you on the male threads of both ends first. Install the shower arm, then then showerhead.
Good Luck!
HTML code is On
