Bathroom Sink Plumbing Guide
Old 07-02-03, 06:43 PM
luisduo
I am installing a new sink and stand in my bathroom, but I've encountered the problem of the current pipes being too short and too far to the right of the new sink.
I would like any advice on what are the guide lines for installing new pipes in the way of making sure I don't have too many angles in the pipes that would prevent it from properly draining.
If you were able to decipher my question, thanks in advance for your help.
Old 07-02-03, 06:44 PM
Plumber2000's Avatar
Is this a pedestal type sink or a vanity?
Old 07-03-03, 08:28 PM
luisduo
It's a vanity sink, which is also higher than the one that was previously installed.
Old 07-03-03, 08:46 PM
Plumbrich
Are the pipes still inside the vanity opening? How far to the right are they from the center of the new sink? What kind of pipes do you have?If only a few inches then flex lines on the water would work.1/8 or 1/6 bend on drain comming from wall.A 1-1/4 ext tube for new height.Let us now how for and we should be able to help.
HTML code is On
