toilet clogged
Old 07-04-03, 02:52 PM
bighenny
Angry toilet clogged
need help my toilet been clogged for two days now. i have been using the plunger every hour on it with no luck.is there anything i can use other then a snake on it like drano or something.
thanks for your help.
Old 07-04-03, 04:24 PM
Mike Swearingen's Avatar
Received 1 Upvote on 1 Post
Cool
You need to get a crank-handle toilet auger to snake the built-in trap of the toilet.
Built-in toilet traps catch almost everything, such as toothbrushes, curlers, feminine products, plastic toys, too much paper, etc.
Do NOT use a caustic drain cleaner in a toilet, such as Drano. It will damage your wax ring seal under the toilet, creating an even bigger problem.
Good Luck!
