toilet tank liner
Old 07-05-03, 11:35 AM
jake
toilet tank liner
I purchased toilet tank liner kits. The adhesive that came with one of the kits had hardened probably due to exceeding the shelf life. Since I have already trimmed the foam, it seems easier to purchase a tube of adhesive / sealant if I can get the right stuff. Could you recommend the proper adhesive/sealant to attach and seal the foam to the ceramic tank.
Thanks
Old 07-05-03, 12:09 PM
Mike Swearingen's Avatar
Cool
I would think that tub-and-tile caulk would work. Just make certain that everything is completely dry when you apply it, and let it cure per the instructions on the tube.
Good Luck!
Old 07-05-03, 01:06 PM
jake
tank liner
The stuff that came with the first kit resembles a type of liquid nails (smell and appearance) - it is a petroleum base. I am not certain of the adhesive performance of 100% silicon tub and tile for constantly emersed conditions. Without 100% sealing and adhesion, I think the toilet will still sweat.
Old 07-05-03, 04:36 PM
Cool
You might try contacting the manufacturer on the Internet for their advice. They may even send you some.
Good Luck!
HTML code is On
