undermount sink fell last night! Help.
Old 07-07-03, 01:11 PM
wrxin
I have a granite countertop in a bathroom with an undermount porcelin sink. It came as a kit with a special epoxy to mount the sink under the countertop.
The sink has been in place for almost 2 years with no problems at all. I came downstairs this morning to find the sink hanging by the drain!
Here's my question, after I clean off all the epoxy, should I buy more epoxy to remount the sink or should I use a silicon caulk, or is there something else I should use?
Thanks very much.
Old 07-07-03, 02:28 PM
T
Porcelan sinks are rather heavy, no amount of silicone will hold it. You'll probably need to epoxy it back up. Usually you have some clamps which are screwed/epoxied into the countop also.
HTML code is On
