Sewage in the Ptrap
Old 07-07-03, 01:16 PM
Sewage in the Ptrap
Hi:
We have a 65-year-old home. In the laundry room in the basement there's a floor drain with a P-trap. It seems as though the P-trap remains filled with sewage, though it doesn't overflow. I've poured a few gallons of water down the drain, and the smell convinces me that it's sewage. As a test, I poured several gallons of water down the drain until the smell became less intense. Then a couple of days later I came back, poured more water, and the smell was as intense as before. Working with my limited knowledge of plumbing, I would not expect this. Any suggestions why this my be happening? Is this an indication of a problem?
Thanks.
Old 07-07-03, 01:36 PM
Mike Swearingen's Avatar
Cool
It's an indication that the main drain line is partially clogged and backing up to the lowest point in the drain/waste/vent system.
Open a clean-out plug and snake the main line from the house to the street or septic tank with a long, heavy-duty plumber's snake.
If that doesn't do it, you may have roots in the line, and it will have to be "roto-rootered", but be aware that this will only last a couple of years at most, and the roots will return.
The only permanent soluition to roots (if that's what it is), is replacing the pipe.
Good Luck!
HTML code is On
