leaking shower
Old 07-08-03, 04:18 AM
Victoria
leaking shower
I have the hot, cold water knobs, and one that turn on/off showers. I found the leak was from the shower (stem?) on/off.
I have remove the stem part and have the local plumbing store look at it, they replace the packing material and still not work, so I have order a new stem, and still leaks, what can I do next before calling the plumber? (try doing myself). please advise. thanks
Old 07-09-03, 05:36 AM
Plumber2000's Avatar
Is the leak all the time or only when the valve is on?
Old 07-09-03, 07:34 AM
Victoria
Thanks for the reply. The leak only happen when the shower is on. I would like to avoid replacing the whole set and cost for plumber. please advise. Thanks
Old 07-10-03, 06:50 PM
Plumbrich
Need to tighten the packing nuts on the stems more.The new stems need the packing tightend they do not come from the factory tight.Example today intalled a new stem had to tighten packing nut 4 full turns to stop leaking.
Old 07-11-03, 03:30 AM
Victoria
Thank you, I will give it a try.
HTML code is On
