New Pressurized Water System
Old 07-08-03, 06:27 AM
sebeach
I'm currently looking to install a new water system at a lakeside cabin.
Currently we pump lake water up 25ft to a ~300 gal holding tank and then use gravity to get the water to the cabin. Unfortunately the holding tank has sprung a leak(s) so its time for something new.
I'm thinking of putting a diaphram tank under the cabin and then using the current pump is down by the lake (it would be about 20ft from the tank). I thint the only problem I have is the pump doesn't have any type of pressure shut off switch. How big of a deal would it be to hook up a pressure switch to turn the pump on and off?
Any tips or comments on this would be greatly appreciated.
Thanks
Old 07-08-03, 07:55 PM
Mike Swearingen's Avatar
Cool
Check out www.peekspump.com and www.jessstryker.com for great info on pump systems.
It isn't difficult to install a pressure switch on the pump or a pressure tank.
HTML code is On
