Water heater replacement
Old 07-09-03, 07:28 PM
mapitts
I have no plumbing experience and need to attempt replacement. If I locate new unit with intake / outtake pipes in same position shouls I attempt this? Are there any special tools required? Any soldering of joints? This is a gas appliance. I've shut off gas supply and drained tank.
Old 07-10-03, 07:09 AM
C
Here are some links on hot water heaters. One about them, and the other on replacment. Check to see if you need a building permit in your locale.
http://www.doityourself.com/plumbing/hotwaterbuying.htm
http://www.chilipepperapp.com/replace.htm
Hope this helps.
HTML code is On
