Kitchen faucet
Old 07-13-03, 09:05 AM
mscal3
Unhappy Kitchen faucet
The pipe underneath my kitchen sink has come away from the drain pipe, the pipe fitting is shaped like a U. When I drain my sink the water goes out from the top of the fitting where the clamp is. How do I go about fixing this problem. I am a woman in distress. Any help would be greatly appreciated.
THANK YOU
Old 07-13-03, 09:46 AM
Mike Swearingen's Avatar
Cool
Charlotte, calm down. (O.K., so I know it's terrible, but I couldn't resist. LOL)
What you probably have is a typical kitchen sink drain set-up with slip-nuts and washers to seal around the drain pipes.
Apparently the trap has slipped out of the drain adapter.
Is there a straight piece of pipe coming out of the trap (the "u")?
If there is, loosen the slip-nut counter-clockwise on the adapter from the wall drain pipe, slide the pipe from the trap into it, and re-tighten it.
If it's white plastic PVC, you should be able to do it by hand. If it is chromed brass drain pipe, you will need a pair of channel-lock pliers or a pipe wrench.
If you need more help, please give us more information about what you see, and we'll be glad to help you.
Good Luck!
Mike
Old 07-20-03, 07:44 PM
mscal3
I would like to thank Mike for his help. That was the solution to my problem. (Although I ended up going to Home Depot) none the less it worked. Thank you so much. I feel so capable now; until something else goes wrong.
HTML code is On
