Kitchen sink - valve leak
Hi there!
First my kitchen sink faucet had some rust underneath so I decided to remove the faucet and clean it. When I was trying to remove the connecting pipe from the valve but found it was welded (is it possible?). While tightening the valve I noticed leak where connecting pipe (copper) meets the valve. I tried teflon tape but didn't stop the leak. How do I fix it? The faucet in kitchen works fine, just that I wanted to clean underneath.
Now if I have to change the valve I have to change the whole faucet because the pipe from faucet is welded with the pipe from the valve. Is there a solution to my probelm other than replacing the whole set-up? Please let me know. Water is dripping very slowly under my sink..
Thanks in advance for suggestions.
Received 1 Upvote
1 Post
The valve is soldered to the copper pipe.
If you're trying to stop a leak at a compression fitting, use pipe dope or teflon tape on the brass ring ferrule, and not on the threads. That should stop the leak.
Good Luck!
Good Luck!
