Hot water pipes
Old 07-17-03, 07:31 PM
landdbro
Question Hot water pipes
The hot water to the kitchen takes along time to get there. I found that the water line runs to the bathroom and then follow to the outside wall back to the kitchen. Can I split the water line at the heater and go two directions without affecting the hot water in the bathroom? Thanks
Old 07-17-03, 08:18 PM
Plumbrich
I cant see any problems with taking a more direct route.Most hot water pressure drops are from cold water before hot water heater not after.So you should be fine.
HTML code is On
