remove a nut from toilet tank
Old 07-19-03, 04:21 PM
I'm trying to remove the toilet tank but couldn't remove the screw and nut as they are bit rusted and they keep rotating. How do I get the tank out? any suggestion?
Old 07-19-03, 07:02 PM
the_tow_guy's Avatar
Received 55 Votes on 45 Posts
If there is sufficient space between tank and base, carefully cut the bolts with a hacksaw. Just had to go that route myself to fix a small leak around one of the bolts.
Old 07-19-03, 07:04 PM
Plumber2000's Avatar
Hacksaw the bolt off between the tan and the bowl, should have room between the tank and bowl to do this,
HTML code is On
