Replacing toilet question
Old 07-24-03, 09:19 PM
warnerwh
I'd like to know if all toilets have the same bolt patterns on bottom? Also do they have the same size drain hole and is it located in the same place. My toilet I believe was installed before I moved in back in 89. Any other advice is appreciated as I've not done this before and know nothing about it. I'd like to do it right the first time. Thank You
Old 07-24-03, 11:24 PM
Plumber2000's Avatar
Yes all toilets have the same bolt positions on them, size on bottom of the toilet does not change the position for the toilet bolt holes.
HTML code is On
