laundry tub clogged
Old 07-26-03, 08:43 AM
peperon
laundry tub clogged
My laundry tub is in the basement . It clogs up and tried draino. Doesn't help too well. Bought a snake today and going to try that. When I use the sink on the second floor bath, the laundry tub seems to fill up again if the water is left on in the second floor bath. If the snake doesn't work, do you think I should check the main stack vent.
Thanks
Old 07-26-03, 10:39 AM
Plumber2000's Avatar
If the tolets flush good then it will be in the laundry drain that is plugged up.
Old 07-26-03, 01:44 PM
peperon
laundry tub clogged
The laundry tub was tied into the soil stack along with the kitchen sink on the floor above. There was a back up of food and stuff. Just took off clean out at the stack and snaked it.
All good now
Thanks
HTML code is On
