Why is softner going thru so much salt?
My water softner is really going through a lot of salt lately. Why is this happening? I use the Morton green rust inhibitor salt. The softener is about 12 years old and I'm not sure of the brand. Thank you.
Received 1 Upvote
1 Post
Every DAY? No.
Your water should be tested for hardness, the usage determined, and the softener set to regenerate only as necessary to take care of that hardness, OR you can experiment with it.
We use about 5,000-7,000 gallons a month and ours is set to regenerate every three days, and works fine.
I think that the softener people must have re-set it to regenerate too often.
Re-set it to regenerate every other day to see if it keeps the water as soft as you're used to, using about the same amount of salt.
If it still seems to be using more salt than you used to use, set it for every three days.
Good Luck!
Good Luck!
