Water Heater Pan
Old 09-02-03, 01:29 PM
Norm Wannabe
Water Heater Pan
I am installing a 50gal electric water heater, and need to put it in a water heater pan. The standard 24" pans from Home Depot come with a 1" female plastic coupling. I'm going to be connecting this to an existing 3/4" male copper connector. (I am in a condo, and the only way to get to the outside is via the existing PRT line that goes down through the wall.)
How do I connect the 1" female fitting to the 3/4" male copper fitting?
Old 09-02-03, 03:01 PM
Plumber2000's Avatar
Use a reducer fitting, 1" x 3/4' bushing
Old 09-02-03, 04:35 PM
That was probably the hardest question ever asked in here wasn't it 2000?
Old 09-02-03, 04:36 PM
Pretty Close
Old 09-03-03, 09:16 AM
Norm Wannabe
Question
Forgive me for asking what could be a dumb follow-up question...but...does this bushing have a copper side to it and a PVC side to it. I can't figure out how to convert the PVC side to the copper side.
Old 09-03-03, 01:26 PM
Ed Imeduc's Avatar
PIPES
A Fpt or a Mpt on a fitting Will be the same in copper, PVC or steel. ED
Old 09-03-03, 05:50 PM
Get a 1" pvc slip bushing x 3/4 female reducer fitting, flue it in and you now have a place to connect the 3/4 copper male adapter into.
HTML code is On
