Storage tank removal.
Old 09-02-03, 04:29 PM
I have a storage tank (50 gal) i have to disconnect tomorow and replace with a new tank.
There is water in the tank (bladder type I think), but no pressure in the system! Do I have any problem I should be aware of?
Changeling
Old 09-02-03, 04:30 PM
if water emits from sifter valve on the bladder side.......the tank is bad.
Old 09-04-03, 02:29 PM
What is a sifter valve?
Changeling
Old 09-04-03, 03:12 PM
sifter valve is the valve you put air into.....like on a car tire.
Old 09-05-03, 09:08 AM
The type of valve a tire or bladder tank uses is called a Schraeder valve. A snifter valve is the type an air volume control uses. Usually consists of a seat, ball, spring and diaphragm.
Ron Peeks
R.L. Peeks Pump Sales
www.peekspump.com
Old 09-05-03, 10:54 AM
I never know if my replys get posted or not untill after I send!!
Something is wrong!
Can someone explain the process for removing the tank when ther is no pressure to remove the water in it?
Can someone explain the wiring of the 220 pressure switch correctly with a two wire + ground system? One wire is black one is white + bare ground.
Old 09-05-03, 02:33 PM
I was close though on the name............it started with an S.
When you wire pump 240, tape a black marker on white wire, everywhere it is visible so you know that those are two 110 legs.
On your master disconnect, DO NOT USE CENTER LUG FOR GROUND.
Drain water completely out of tank.....by cutting pipe loose at bottom or by means of a boiler drain.
HTML code is On
