Same ampage required?
Old 09-04-03, 09:28 AM
snissors
Considering replacing my ISE Badger 1 with a slightly higher model.... perhaps increasing amps needed by about 1. Will this jump typically cause problems, or is that small enough of an increase that I don't need to worry about it?
If I do need to worry about it, how do I check what my electrical supply line can handle?
Thanks!
Old 09-04-03, 10:34 AM
14-2 wire is 15 amp rated
12-2 wire is 20 amp rated
If wire is very pliable and thin, it is most likely 14-2 wire.
Garbage disposals always draw under 15 amps in most residential applications.
I installed a insinkerator high-end model and it's total draw was 8.3 max load.
HTML code is On
