Water level in tank to low
Old 09-10-03, 05:58 AM
Special Kay
Unhappy Water level in tank to low
Hi,
At first the toilet would not stop running, so I replaced the flapper. That worked fine. But now after the repair and the tank refilled the next morning the water level was low. I filled the tank again, and flushed. The toilet flushes fine, but the tank will not refill until I turn on the water in the bathtub? Could there be a clog that is causing this problem or is it something bigger?
Old 09-10-03, 08:58 AM
Restriction in the fill valve. Take valve apart and clean. Or replace.
HTML code is On
