How do I fix this
Old 09-14-03, 03:04 PM
Its_Mine00
How do I fix this
My toilet is not flushing properly. In order for it to flush I have to hold the handle down and sometimes repeat flushing. What can I do to fix this problem?
Thank you for your assistance
Cassie
Old 09-14-03, 04:12 PM
Plumber2000's Avatar
Could be the parts in the tank are in need of replacing, try replacing the flapper and the fillvalve see if that helps, other things could be wrong, like the flush ring plugged up or the blow hole plugged up, things to check out.
HTML code is On
