Toilet Still Leaking
My toilet leaks from the tank to the bowl. I've tried replacing the flapper but it still leaks. Even when I apply a bit of pressure to the top of the flapper to ensure(?) closure, it still leaks. This sounds impossible doesn't it? Any ideas what's up?
Thanks.
cthoms
Thanks.
cthoms
Make sure the tube that comes off of the fillvalve that goes into the overfill tube on the flush valve is not below to water full level in the tank, it needs to be above that point, or it can siphon the tank, causing it to turn on and off all the time.
Hello, the overflow tube could be cracked or the gasket at the bottom of the tank just below the flapper could fail. Flush the toilet and when the tank is full shut off the water to the toilet. Let it set a few hours then check the level, if the water is close to the top maybe the overflow is too far down in the tube. The water will stop at the leak if it stops at the flapper then check that again or the joint where the overflow pipe connects to the assembly behind the flapper. If the tank is completly empty the gasket leaked. Good Luck Woodbutcher
I think that I'm having this same problem in one of my bathrooms, I noticed that my toilet was making a small constant dripping noise. I pushed down on the flapper thing and it seemed to stop until the next time my son flushed the toilet. Is it very difficult to replace the flapper?
Thanks, going to Home Depot today, Goodness I love this place!!! I think I could probably build a whole new house with the help I get here. Plus I make myself look even more intelligent to my husband when I can fix things. He marvels at me, and I don't dare tell him that I get my smarts from here. LOL
