shower leak
Old 09-25-03, 06:44 PM
shower leak
My shower leak. I saw calcium deposit around the drain pipe. How do I locate the leak? Should I replace the drain or should I regrout all the tile? My drain is a copper cup with a lead pipe connected on the side. How do I disassemble the drain?
THanks
Old 09-25-03, 08:48 PM
First determine if it is a drain leak or a tile leak.
If it is a drain leak, you might have to update your drain assembly in order to remove the problem.
Old 09-25-03, 09:08 PM
Plumber2000's Avatar
Plus if you need to update the drain, guess what, time to rip out and redo the tile.
HTML code is On
