Replacing a Sump Pump
Old 09-27-03, 05:26 AM
Royal
How difficult is it to replace a sump pump? I looked at them on the Lowes website, and we have a submergable pump. Is it as easy as just pulling out the old one and submerging the new one and plugging it in???
Old 09-27-03, 06:41 AM
brickeyee
Except for you omitted hooking up the discharge pipe, yes it is that easy. If you are lucky the original installation included a union to disconnect the discharge line.
Old 09-27-03, 07:21 AM
Royal
For whatever reason, ours is not releasing the water from the rain last night, and there is water in there. I can't really see where there is a discharge pipe, but should it be very difficult to remove the discharge pipe from the old unit and install it on a new unit?
Old 09-27-03, 01:23 PM
brickeyee
You need to figure out how it is hooked up to the discharge. the water goes somewhere :-). The biggest problem is usually reaching down into the pit if the pipe is not exposed. I prefer putting a union within a few feet of the floor outside the pit. It makes servicing a lot easier down the road.
HTML code is On
