Kitchen sink help
Old 09-30-03, 04:29 PM
Martin68
Kitchen sink help
I moved into a house that has corian(probably a mispell)countertops.I want to replace the faucet.The faucet wobbles because he never installed the mounts.I looked under the sink to find that he used small rectangle pieces of the corian to shim the sink itself and that it is where the mounts would go.I can even see where a screw or something is to hold the sink up.
1.I know nothing about sink installs.
2.How would I go about moving the shims if they are in there tight(looked glued)
3.If I did get that far,What type of bit would I use on a drill to put mounting holes in corian?
Old 09-30-03, 09:22 PM
Corian tops are very expensive. If you are unsure of this process of changing this I would hire a licensed plumber for this task and that way he or she holds the responsibility of the final product to you the consumer.
Old 10-02-03, 05:07 AM
awesomedell's Avatar
Got to agree about hiring a pro for this, but I'd suggest you might want to go to the guys who install these tops, you've got to have the right tools for dealing with the material to avoid damaging it. Just my $.02 worth.
Old 10-04-03, 07:51 AM
Martin68
re
Ok Thanks Guts
Martin68
re
Ok Thanks Guys
HTML code is On
