Bath Tub Plumbing
Old 09-30-03, 11:56 PM
iKwak
Bath Tub Plumbing
The water is not going down well in the bath tub plumbing.
Where could I rent those equipment that has a long hose to insert inside the bath tub hole? I saw a plumber use those.
Old 10-01-03, 04:16 PM
notuboo's Avatar
Any rent-all place with have the drainline snake you need. Use a 1/4" cable machine and go through the tub overflow opening.
Another option to consider is to plug the tub drain and use a shop vac (Rental on these available also) to suck the drain line from the same tub overflow. Good shop vac will clear the line in no time.
More problems, ask and someone will help you.
HTML code is On
