Water heater popping
Old 10-02-03, 06:39 AM
Tipper
Question Water heater popping
After taking showers, my gas water heater popsfor several minutes. The sound emanates from inside the lower half of teh tank. It might pop for a few minutes intermittently then stops.
Any thoughts on cause and repair.
Thx Tipper
Old 10-02-03, 07:07 AM
thiggy's Avatar
Mine does the same. I just chalk it up to expansion/contraction of the tank due to the cooler water being brought back up to temp. I can't think of any repair being necessary.
Old 10-02-03, 08:53 AM
Rainbird's Avatar
Hook up a hose to the drain valve and flush the water heater. This will remove the sedaments that are causing the poping noise. Flush until it runs clear water.
HTML code is On
