Removing ceramic bath fixtures
Old 10-03-03, 03:33 PM
northernlady99
Question Removing ceramic bath fixtures
Does anyone know how to remove old ceramic wall fixtures from painted sheetrock walls. I have a toilet paper holder and towel rack I want to remove and replace.
Thanks
Old 10-03-03, 04:28 PM
In all likelihood, they are glued on. Removing them is going to damage the sheetrock. Cut around them with a razor knife to limit the amount of damage, then knock them off with a hammer. Patch the sheetrock as needed and install the new ones.
Old 10-03-03, 04:57 PM
notuboo's Avatar
There will be a little metal slide behind the ceramic base. Hit it upwards after you cut off the wall with a razor or utility knife.
Cut the sheetrock deep enough so the sheetrock paper will not tear as you remove the ceramic bases.
Good luck with your project...
HTML code is On
