wall mount faucet
Old 10-13-03, 03:53 PM
pascal
wall mount faucet
I'm trying to install a new wall mount faucet on my kitchen sink. The problem is that I can't get the backplates from the old one off. Any suggestions? Thank you.
Old 10-13-03, 05:33 PM
trenchlessman
there is a special tool that you need to unscrew this fitting. I use a seat wrench. just look inside and you will see a small square about 5/16" or so. then go to your local hardware and see if they carry a tool like that.
Old 10-20-03, 04:42 PM
pascal
: THANK YOU!!!
Old 10-26-03, 02:19 PM
pascal
Now I've got another problem. The new faucet doesn't fit properly over the holes in the cast iron sink. The holes are bigger than those found on modern sinks. I cannot resuse the old backplates because they don't fit the new faucet. Any suggestions as to where I can buy a faucet or backplates that fit?
Old 10-28-03, 02:06 PM
trenchlessman
You need to post a picture of this faucet if you can or send me a pictre of it and the oversized holes.
[email protected]
www.dalestrenchless.com
HTML code is On
