Loud Noise in the Bathroom
Old 10-29-03, 08:02 PM
LilKatCharmer
Unhappy Loud Noise in the Bathroom
All of a sudden, there was a loud vibrating/buzzing noise in our bathroom. We first thought it might be the fan, so I turned it off, but the noise didn't go away. It seemed to be coming from the toilet and shower area, but from behind the wall. It stopped gradually. We turned the water off going to the toilet and adjusted the floating ball in the toilet to stop the toilet from running.
The noise was really loud. Any ideas what it might be and what we can do?
Thanks,
Kristy and Deanna
Old 10-29-03, 08:06 PM
Mike Swearingen's Avatar
Cool
It's the water valve in the toilet tank.
Get a Fluidmaster 400A float-cup type (about $5-$7 bucks), and follow the installation directions that come with it. Easy.
Good luck!
Old 10-30-03, 08:21 AM
Binary Bob
I have the same problem!
It's affirming to know I'm not alone!
When my wife is in the bathroom there is intermittant exploding noises. Hard to pinpoint since it is sporadic, but it seems to be coming from the toilet area.
The noise can be really loud. I've checked everything I can think of. She is not cooperating with my troubleshooting efforts. Any ideas?
Old 10-30-03, 09:11 AM
kaybyrd's Avatar
guess i shouldn't complain
I have a singing toilet. I thought it was a bother, but thank goodness it doesn't make a loud noise. Just sounds like a quiet slow two tone doorbell ringing at times. I understand that its from the toilet not being perfectly level and causing the porcelain to vibrate, but I can't seem to accomplish the perfect level.
Kay
Old 10-30-03, 09:24 AM
Cool
Those toilet tank water inlet valves come in all sorts of brands and configurations, and can make all sorts of weird noises when parts start wearing out.
Replace it and it should solve your problems.
Good luck!
Old 10-30-03, 09:42 AM
kaybyrd's Avatar
It did that from the day we bought it. Do you think that changing out the 'innards' would solve it. It isn't too annoying, in fact I can put a piece of thin hard plastic between the tank lid and the tank and it stops the noise.
I didn't give but $100 for the tank so it may have come with super cheap parts.
Kay
Old 10-30-03, 10:13 PM
Cool
Yep.
If it makes weird noises like that, it is most very likely the tank valve, new or old.
Good Luck!
Mike
Old 10-31-03, 05:10 AM
kaybyrd's Avatar
This makes me feel better. I thought maybe that I was seeing "unlevel" or something!
Kay
HTML code is On
