Low water pressure?
Old 11-19-03, 11:17 AM
Low water pressure?
Just today our water pressure has dropped significantly. We are on city water, not well. I checked with our next door neighbor and he isn't experiencing any drop in pressure. Any ideas what this could be? My first thought was a busted pipe somewhere but, luckily, I can't find one...not inside at least. Should a plumber be called? Any thoughts would be appreciated. Thanks.
Jeff
Old 11-19-03, 01:30 PM
Mike Swearingen's Avatar
Cool
Turn the main water valve off at your home and check the leak indicator on your water meter. It probably is a small triangle or gauge.
If either is moving, you may have a leak between the meter and your home, or your main valve is leaking.
The other possiblilty is that you have a Pressure Reducing Valve after the meter that needs re-adjusting or replacing.
Good Luck!
HTML code is On
