plumbing
plumbing
Hey guys I also got a plumbing question Im sure you can answer. I have a floor trap right next to the can in the bathroom . The sink drain runs into it and so does the tub well in the past we have had problems with that leaking and it has ruined the kitchen ceiling we plan on redoing all the drain lines in the bathroom once we tear apart the kitchen. Because we have had alot of problems with the line that drains the sink, Lots of clogs. And its that trap where the clogs originate from causing it to leak. So when I run the new plumbing I dont need that trap ?? Thanks
Ahhhhh,,,,I see. Kind of like a indirect waste eh?
Well, it would be a good idea to eliminate since it is not considered a normal setup. Post back with questions when you reach that point.
