New Fangled Pex
Old 01-26-04, 05:01 PM
appliancepresid
New Fangled Pex
Hello All,
Which is better Rehau or Wirsbro pex and which tools are the least expensive, Any and all info on the new pex not qest-pex
would be helpful
Thanks in advance
Old 01-26-04, 05:28 PM
Plumber2000's Avatar
Received 2 Upvotes on 2 Posts
I only use RTI fittings, the tool can be used for sizes 1/2" to 1" in size. Tool runs about $115. Pex pipe is Pex pipe, just manufacturers of the different fittings give a name for there pipe, just each type will use there special tool.
Old 01-27-04, 12:03 PM
rav12's Avatar
There is also a cheaper tool (about $50) which involves bolting two halves using a wrench to make the crimp. Works OK but may be difficult to use in confined spaces. The two ends usually can do two different sizes.
Check www.pexconnection.com - they have a good selection of tools ranging in price.
