Nosy Drain Pipes
Old 01-27-04, 08:07 AM
CutterElk
Smile Nosy Drain Pipes
This might seem like a dumb question. When water drains from our Bathroom sink, it makes cracking nosies. Nothing is leaking, the water drains just fine. Just a little cracking sound comes from the pipes when it drains. Any ideas. Does it have to do with that I live in Minn. and it is really cold here??
Thanks
Andy
Old 01-27-04, 08:12 AM
Plumber2000's Avatar
Received 2 Upvotes on 2 Posts
Could be hearing expansion and contraction of the drain pipe.
Old 01-27-04, 08:15 AM
CutterElk
re:
So this is nothing to worry about? Should I replace the drain pipe?
Old 01-27-04, 08:56 AM
No, leave it alone.
If it's not broke, don't fix it.
Old 02-17-08, 10:00 PM
T
noisey drains
i dont think u living in minn. has any thing to do with it. i live in calif. and my bathroom sink drain all of a sudden is very noisey. it makes a glupping sound or maybe it could be called a cracking noise. i would like to know what is making it do that all of a sudden. i know this doesnt answer your problem but i thought i would put my 2 cents in on a calif. noisey bathroom sink drain.
Old 02-18-08, 12:18 PM
F
Received 39 Upvotes on 31 Posts
It is a four-year-old thread, thatsthat9 but it is possible that your problem is a plugged vent.
Old 02-18-08, 03:45 PM
W
Received 13 Upvotes on 11 Posts
Hi,
Hot water will cause the ABS pipe inside the wall to expand and rub against the wood. That will give you that sound.
Good Luck Woodbutcher
