Stripped Valve
Old 01-31-04, 03:25 PM
flynnternet
Stripped Valve
I am installing a RO Water Filter, and while turnin on and off my cold water shutoff valve (to check for and attempt to fix leaks), it seems I've stripped the knob. Luckily it's stuck in the closed position.
Any advice on how to either fix it or replace it?
Thanks much.
Old 01-31-04, 04:40 PM
Mike Swearingen's Avatar
Cool
Replace it. They're inexpensive.
Sitting up for long periods of time in the open mode causes them to get corroded, etc.
Good luck!
Old 01-31-04, 05:15 PM
flynnternet
I live in an apartment and don;t have access to the main water supply. If I take out the valve, won't I get a flood?
Old 01-31-04, 05:34 PM
Dave_D1945's Avatar
You probably will get flooded if you can't shut something upstream of your valve.
Maybe your apartment maintenance people can help you find a way to shut down long enough to replace your valve.
Old 02-01-04, 12:50 AM
Cool
If you live in an apartment, the shut-off valve is their problem.
Call your apartment manager or the maintenance department.
If it is just the handle that is stripped, you can probably turn it back on with pliers temporarily.
Good Luck!
HTML code is On
