ejector pump installation
Old 02-15-04, 01:47 PM
plateblocker1
Question ejector pump installation
Looking for information/tips on installation of ejector pump for bathroom in basement. Shower/Tub, Toilet and sink will be on the same wall with the ejector/basin on the other side. My questions are:
1) In venting these 3 fixtures, is the vent pipe from the ejector basin sufficient? In others words, all 3 will drain directly to basin, then vent from basin.
2) Is there a max distance from pump to sewer drain to run PVC?
I have 8 foot celing in basement then a horizontal run of 12' to sewer.
thank you
Old 02-15-04, 02:04 PM
Plumber2000's Avatar
Answer::: Absolutely NOT, The sump pit must be vented alone out the roof at 2", can not tie with other vents and can not be used to vent other fixtures.
Answer::: Not at all, just when to get this pump, make sure it's a sewage ejector pump, ask at a plumbing supply house, they will get you the correct size you need, tell them how far your pumping to.
HTML code is On
