moving plumbing for sink
I want to install a corner pedestal sink in our tiny 3X5 powder room BUT the pipes are in the wrong place. How hard is it to move them about 6 inches to the right. I know how to finish the drywall once the job is done, I just don't know how difficult it will be to move the pipes. (p.s... is this called "roughing in" the plumbing?)
bpt
bpt
Well, not good.
You have to have a knack to work with threaded fittings, which it sounds like that would be your only option.
If you knew how to solder, it would be simple to switch materials and make the changes, but for the drain, that will have to be cut and transitioned to pvc to make that feasible.
There is a little bit of time involved in what you are describing.
If you can, take pictures of your situation, go to www.photobucket.com and provide the image link so that we can better help you.
