dishwasher problems
Old 02-29-04, 01:37 PM
slssrs1
dishwasher problems
When running the dishwasher, the water backs up into the sink. The water eventually goes down. The dishwasher has a pipe running from it to the garbage disposal. Could this be a clogged pipe? If so, where could the clog be?
Old 02-29-04, 05:43 PM
If the sink is backing up, it has nothing to do with the dishwasher.
If the sink only backs up in the side where the disposal is, then it is the drain line from the disposal to the center or end outlet waste.
But if both sinks are clogging up, then you need to cable the drain to remove the clog.
HTML code is On
