washing machine drain height
Old 03-06-04, 11:26 AM
Linda1477
Question washing machine drain height
My son has recently purchased a fixer upper, and he would like to put his washing machine in the basement, but there is no floor drain. How high will a washing machine push water?? Could we plumb it into the bathtub drain above the washer?? Basement height is appox. 7 feet.
Old 03-06-04, 04:45 PM
No. The maximum height a washing machine can pump is to the height of the top of the machine. Anything higher will cause problems and force the pump to work harder than what it was designed for.
Old 03-06-04, 07:57 PM
L
Received 1 Upvote on 1 Post
You're son will need to install an ejector pump system, or move the WM upstairs.
