Gas Shut off valve
Old 03-13-04, 05:26 AM
Martyg3
Gas Shut off valve
The handle on my gas shut off valve snapped off. Is there a way to just replace the handle or do I need to replace the whole valve.
Old 03-13-04, 05:36 AM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Votes on 4 Posts
Hello Martyg3. Welcome to the Do It Yourself web site.
The handle, if it's a lever type may be replaced seperately but not advised nor recommended. Chances are one will not be able to be purchased seperately, even if it is the type with a center screw.
If the lever broke off the valve, it is an indication the ball or core in the valve is frozen in the body of the valve. Not a safe valve if it cannot be turned by the hand operating lever.
Replacing the entire valve is highly recommended and suggested.
HTML code is On
