humming sound
Old 02-16-00, 11:38 AM
Post
humming sound appears after hot or cold water taps have been run. It will stop if you turn the taps back on.
Old 02-16-00, 10:23 PM
Post
PROBOBLY YOUR PRV.
YOU CAN CHECK THE PRESSURE AT THE BOTTOM
OF YOUR WATER HEATER WITH A WATER PRESSURE
TEST GUAGE,SHOULD NOT EXCEED 80 PSI,IF IT
DOES YOUR PRV IS BAD.
Old 02-17-00, 05:33 AM
Post
Is it every faucet,if not it could be the faucet washers or the faucet stems. Good luck
HTML code is On
