Rough Plumbing
Old 02-21-00, 06:16 PM
Question
Is there very much of an advantage to insulating the hot water lines that will be located under the slab?
Old 02-22-00, 06:11 PM
Post
IF YOU ARE USING COPPER THEY NEED TO BE SLEVED,YOU WILL LOOSE ALOT OF HOT WATER ENERGY IF THE PIPES ARE IN DIRECT CONTACT WITH THE SUB-SOIL. YOU CAN USE THE RUBBER SPLIT SEAM INSULATION / SLEVING ON THE
UNDER GROUND WATER PIPING,BE SURE THE INSULATION EXTENDS ABOVE THE FINISHED FLOOR.
HTML code is On
