Clogged drain
Old 02-29-00, 07:41 AM
Question
I have a clogged kitchen drain. I have tried Draino, boiling water, plunger to no avail. I have a double sink with disposal on one side. Any suggestions for this frustrated female?
Old 02-29-00, 04:37 PM
Post
If the clog is from the wall to the P-Trap a plunger should work. One common problem is for someone to plunge a sink on one side but not plug the other side. You could fill both up with water if you have not tried that and plung either side. If that does not work it usually works best to take the P-Trap apart and if the clog is in it you will know and if not run a "snake" down the drain where the P-Trap come off. That however might be more trouble than you asked for.
quote:
HTML code is On
