Whistling shower head?
Old 03-28-04, 06:35 AM
patj735
I just had a large additon put on our home.We got a new water service,New hot water boiler and water maker,new hot water baseboard heat.I had all new drains and plumbing replaced in the original bath.When I use the shower it makes a whistling sound.What is the cause?Should I replace the old shower head?Any suggestions would be appreciated.
Old 03-28-04, 07:23 AM
Rainbird's Avatar
The problem could very well be the 2.5 gpm water restrictor in the shower head. You can remove the head and take out the restrictor, or install a new shower head.
The problem could also be inside of the faucet itself, this would require a repair to the faucet to correct the problem.
Old 03-30-04, 01:11 PM
caleyg's Avatar
That's funny--mine started whistling when I took the flow restrictor out!
But I can get wet in the shower without having to run in a circle now!
Old 03-31-04, 12:15 PM
patj735
Thanks for the advice Rainbird.I'll let you know what happens.Thanks again.
Old 04-26-04, 06:38 PM
cdfree
I had the same problem and replaced that faucet head and thing that switches from bath to shower--worked like a charm.
HTML code is On
