joining dissimiliar pipes
Old 03-02-00, 06:35 AM
Guest
Post
At a kitchen drain where metal pipe is used and attaches to a leaded pipe, can plastic pipe be used to replace the metal pipe? How can plastic pipe be effectively threaded to the metal pipe?
Old 03-02-00, 08:51 AM
Guest
Cool
PVC plastic drainpipes have threaded slip nuts and washers that fit right onto metal pipe threads. Just ask at the hardware store.
Old 03-02-00, 03:38 PM
Guest
Post
Are you saying there is metal pipe under the sink that attaches to lead pipe coming out of the wall?
quote:<HR>Originally posted by robt:
At a kitchen drain where metal pipe is used and attaches to a leaded pipe, can plastic pipe be used to replace the metal pipe? How can plastic pipe be effectively threaded to the metal pipe?<HR>
Old 03-02-00, 06:04 PM
Guest
Cool
I'm just saying that if you have a threaded pipe fitting coming out of the wall, on whatever type of pipe that there is, a PVC plastic fitting (nut and rubber washer)will connect to it.
Old 03-04-00, 06:57 AM
Guest
Post
Usually plastic and metal work together inder the sink. If you wanted metal to metal use a metal slip nut with a plastic washer that also works fine. Lead pipe can get fragile over the years so be aware of that.
<HR>
